I am planning on buying a ASUS AMD Radeon RX 5700 and putting it into my Versa H18 case. Four slots total on the case to put a gpu, and the top slot is being used by my wifi card.
I've tried measuring out how it would fix and I can not tell if it will or not and how much clearance it may have. If you guys could help me out that would mean a lot
https://linustechtips.com/topic/1180754-gpu-clearance-issue/
the board makes all the difference here. If you cant use the Wifi card on the bottom PCIe bracket of the case (as the board doesnt have a slot there), you'll have to ditch WiFi card and opt for a USB solution, or opt for a different mATX board (in 99% of cases, not worth it) with or without WiFi built in, or an ATX board and ATX case.
Desktop benching:
https://linustechtips.com/topic/1180754-gpu-clearance-issue/#findComment-13502094
what mb are you even using?... That wifi card can go into a regular pciex slot too
https://linustechtips.com/topic/1180754-gpu-clearance-issue/#findComment-13502107
I do not see the issue.  Why do you think it would not fit?  I have something very similar, but it is a pciex sata card instead of a wifi card sitting above the gpu.  The only reason I put mine there is because my sata cable was about 1cm short to move it to the bottom
https://linustechtips.com/topic/1180754-gpu-clearance-issue/#findComment-13502158
