Stream Labs OBS Stutter on stream
Solved by TylerLovekeeper,
1 hour ago, NotSoEpicMods said:Was reading some other posts with stuttering issues and apparently an overloaded GPU can cause Stuttering even though you're using the CPU for encoding. Maybe try limiting the graphic settings on the games you're having problems with? Also there should be log files for SLOBS located in '%appdata%\slobs-client\node-obs\logs'
omg, i think i figured out the issue.... MSI Dragon center was set to silent mode and was limiting CPU to 2.8Ghz I set to performance it bumped up to 4.2 and now stream is fine
