Board : ROG STRIX B450F Gaming
CPU : Ryzen 7 1700 or
Athlon 3000g which I borrowed from Newegg to try and fix this problem..
Did a bios flash to the latest revision and it seems that it is not compatible with my 1700. So I got the cheapest 2019 processor figuring that would solve the issue and I still have a CPU light with no display or I get a scrambled image photo is below.. That is using the Apu, no display at all with gpu...
So I need to flash my bios back without a display or get Ryzen 3000 series chip? Any ideas of how to get it running... PC powers on fine fans and RGB, no display
https://linustechtips.com/topic/1179521-no-display-cpu-light-on/
If the BIOS update borked the motherboard, you'd have to send it in for RMA unfortunately. If it works with neither CPU, you don't have a working board.
Primary PC:
PSU tier list
How many watts do I need?
did not fix the issue ... I tried 3 different Cpus thinking that it might be compatibility with the bios, it turned out the bios is bricked ... I ordered a new board.. The same one ...  If anyone knows how to replace a bios chip and wants a new board let me know
