I got everything planned out then realized I don't know how I'm going to mount the graphics card. I got a riser cable to mount it lying flat to see the card's design and help get rid of vertical height but I can't figure out how I'm going to mount it. I saw Linus's desk PC videos but I didn't understand how he mounted the graphics card. I'm doing a very similar build just not liquid cool the graphics card and this is the video https://www.youtube.com/watch?v=jxAPtBZQc3M&feature=youtu.be&t=296
https://linustechtips.com/topic/1179209-making-a-desk-pc-help/
Just now, PlaguedSloth said:
My main problem is how to mount it to the desk like he said with the inserts but I just don't understand how he did that.
thats what i saw when he removed the gpu.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1179209-making-a-desk-pc-help/#findComment-13490868
i rewatched the video. for some odd reasons, it looks like he either glued it on or just put it on top of the stands since the wooden stands looks like its away from the screw holes on the gpu,
CURRENT PC SPECS
https://linustechtips.com/topic/1179209-making-a-desk-pc-help/#findComment-13490886
nevermind. there was a continuation on the video. he screwed it in through the gpu PCB.
CURRENT PC SPECS
https://linustechtips.com/topic/1179209-making-a-desk-pc-help/#findComment-13490895
