2 minutes ago, cutelittlebabyboss said:
Hi guys, so i'm quite confused what is the difference between Lian Li O11D and Lian Li O11D XL. Other than the 2 extra usb 3.0 ports at the front for Lian li O11D XL, what more?
Other than extra ports... Essentially it's larger and wider than the Lian Li O11D
XL is bigger, can take more drives and has 1x external fan
also I/O
standard
Technical Details:
  • Dimensions: 272 x 446 x 445 mm (W x H x D)
  • Material: Steel (interior), Aluminium (front), tempered glass (front, side)
  • Weight: approx. 10,1 kg
  • Colour: Black
  • Form Factor: E-ATX, ATX, Micro-ATX
  • Total Possible Fans:
    3x 120 mm (bottom)
    3x 120 mm (top)
    3x 120 mm (side, front)
  • Radiator Mountings (forefeits fan slots):
    1x max. 360 mm (top) - Maximum Width inc fans: 90mm
    1x max. 360 mm (bottom, forfeits SDD brackets) - Maximum Width inc fans: 85mm
    1x max. 360 mm (side, front) - Maximum Width inc fans: 50mm
  • Filter: Bottom, top, side panel
  • Drive Bays:
    2x 3,5" drives (internal)
    4x 2,5" drives (internal)
  • Power Supply: 2x ATX (optional)
  • Expansion Slots: 8
  • I/O Panel:
    1x USB 3.1 Type C (internal connection)
    2x USB 3.0 Type A (internal connection)
    1x Audio In/Out
    On-/Off switch
  • Maximum GPU Length: 420 mm - Maximum GPU Height 158mm
  • Maximum CPU Cooler Height: 155 mm
  • Maximum Power Supply Length: 255 mm
XL
Technical Details:
  • Dimensions: 285 x 471 x 513 mm (W x H x D)
  • Material: Steel (interior), Aluminium (roof, side, front, feet), tempered glass (front, side)
  • Colour: White, black (HDD cages, gromits, tempered glass frame, dust filters)
  • Form factor: E-ATX, ATX, Micro-ATX, Mini-ITX (EEB with additional expansion kit)
  • Total fans possible:
    3x 120 mm / 2x 140 mm (bottom)
    3x 120 mm / 2x 140 mm (roof)
    1x 120 mm (rear)
  • Radiator Mountings (forfeits fan slots):
    1x max. 360 mm / 280 mm (roof)
    1x max. 360 mm / 280 mm (base)
    1x max. 360 mm (side, forfeits SDD brackets)
  • Filter: Bottom, roof, side panel
  • Drive bays:
    4x 2,5/3,5" drives (internal)
    6x 2,5" drives (internal)
  • PSU: 1x ATX (optional)
  • Expansion slots: 8
  • I/O Panel:
    1x USB 3.1 Type-C (internal connection)
    4x USB 3.0 Type-A (internal connection)
    1x Audio In/Out
    On-/Off switch
  • Max GPU length: 446 mm
  • Max CPU cooler height: 167 mm
  • Max PSU length: 210 mm
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
