Tech yes city viewer here huh?
Anyways the cooler should be ok, the 3600 is not a very power hungry part and with ryzen 3000 oc is not very practical, if you have already bought the cooler there is no need to ask the qestion
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
https://linustechtips.com/topic/1178704-cooling/#findComment-13486811
Thanks mate
https://linustechtips.com/topic/1178704-cooling/#findComment-13486817
