Hello people, my front usb slot do not work and i need usb slots, I bought a usb 3 hub , my mobo is in the signature below, where should I plug this usb hub, to have as much power, I need to plug my printer, camera, a connection for phone transfer and the mouse (Razer nags RGB) will it handle all those without causing any problems?
Thanks!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1178238-front-usb-case-do-not-work/
Not everyone has signatures enabled, I don't ... so I can't see what motherboard you have.
If you mean msi z390 gaming edge  , you have usb 3 and usb 2 headers on the motherboard
See manual (i attached it) or see link here : https://download.msi.com/archive/mnu_exe/M7B17v2.1_EURO.zip
Pages 23-25 show you where the usb headers are on the board
Page 14 also has an overview of the board where all connectors are named.
So you just need to open your case and take the cables from the front panel usb connectors and plug them in the proper headers on your motherboard.
Front panel connectors are typically for things that you disconnect and connect often, so imho a printer usb cable is not supposed to go there.
Just plug the printer usb cable in the back in a usb 2.0 port (because the printer doesn't need more than 20-30 MB/s of transfer speed)
Same for the camera - plug it in the back in a usb 3 port.  Same for the mouse.
The hub ... depends on hub ... if it doesn't have a separate power supply, just plug it in the back in a usb 3 port, doesn't matter which one.
7B17v2.1(G52-7B171XD)(MPG_Z390_GAMING_EDGE_AC)EURO.pdf
7B17v2.1(G52-7B171XD)(MPG_Z390_GAMING_EDGE_AC)EURO.pdf 13.65 MB · 0 downloads
The motherboard is the MPG Z390 Gaming Edge AC.
And i want to plug the USB HUB behind, which is the best port to plug it in (power ect..)?
the usb 3.1 GEN 2, or the usb 3.1 GEN 1?
Doesn't matter ... all ports have the same amount of power, 0.9A at 5v ... 4.5w in total.
2 or 4 ports are grouped together and protected with a fuse that's typically rated for 2-4A , so if only one out of 2 or 4 usb ports are used, that single port may take 2-4A of current.
I told you about the headers so that you could double check and maybe get your front usb ports working.
If they're damaged physically (bent pins inside the connectors or broken cables) but your case has 5.25" bays (optical drives, whatever) you could also buy something like this:
https://www.ebay.com/itm/20Pin-to-2-USB-3-0-port-HUB-HD-audio-pc-floppy-front-panel-expansions-rack-3-TE/124000789081
If you want loads of power, get something like this : https://www.ebay.com/itm/Motherboard-20-Pin-to-USB-3-0-4-Port-Front-Panel-Bracket-For-5-25-CD-DVD-ROM-Bay/352079802332?epid=942235751&hash=item51f9976fdc:g:ZrcAAOSw-3FZNgxf
it has a usb 3 hub chip, which takes 1 usb 3.0 connection (from a usb 3 header) and creates 4 ... and also takes power from a molex (old hdd connector) so each of the ports can basically give a lot of power to device plugged in. The molex connector is good for at least 5A of current.
