Dual Monitor Upgrade/Ultrawide
KingSeamusII
Hi all,
I hope you're keeping safe and enjoying the "forced" gaming that we are now all having to do. I've recently come out of hospital due to Covid-19 and will be working from home for the remainder of the year.
To that end, i am re-imaging my current home set up and my current 1440p 60hz monitor will be re-purposed as an additional monitor to my work laptop.
This coincides with a moving to an ITX build for which the parts are en-route. The build will be running a 2700x and Gigabyte windforce GTX 2070 from my current build.
I'm after either, dual monitors or an ultrawide which is 1440p and 144hz. Duals should be either 25 or 27". I was considering the Dell U2718Q until i realized it was 60hz.
Budget wise i'm looking at £600.00 in total if that is even achievable.
Any suggestions would be ideal, i'm happy to buy from the clearance section if there is a paticularly good deal.
