Need suggestions for a PSU at High FPS
Solved by seon123,
52 minutes ago, Pikatchu said:EVGA G+,
They had issues with an ACRF PSU, so you suggest them... The same model, but fully modular...
50 minutes ago, MartinKweh said:agreed since higher wattage capacity PSU tends to not get stressed as much since you will most likely not hit its max capacity
It has more likely to do with the topology on the primary side being ACRF, rather than a higher end, like half bridge + LLC. You would be more likely to have coil whine on e.g. a G5 750W than a Formula 450W.
58 minutes ago, itsdres said:I suppose $250 or less.
Where are you buying from? The availability and pricing will vary
