I would just wait until the virus blows over and many more are in stock, that should drop the price. I've been wanting to get a new computer monitor due to recent technical issues but all of the highly rated ones in my price range are out of stock.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/1176609-help/#findComment-13471240
Sameee dude what monitor do you think I should get if I get the RX 5700 with my CPU?
https://linustechtips.com/topic/1176609-help/#findComment-13471256
Not quite under $300, but very close with Promo code and rebate.
https://www.newegg.com/msi-radeon-rx-5700-rx-5700-mech-oc/p/N82E16814137466?&quicklink=true
F@H    EOC
Folding Rigs
Toaster Oven: RTX 3070 Ti & R5 7700X
Meth-Uselah: RTX 2070S & R5 3600X
Pecan't Pi: Raspberry Pi 5
ZZ Laptop: Asus ROG Zephyrus G15
https://linustechtips.com/topic/1176609-help/#findComment-13471273
Just now, Randy B said:
Sameee dude what monitor do you think I should get if I get the RX 3700 with my CPU?
I've just recently started researching them so I wouldn't know. It depends on what you want such as screen size, resolution, panel type, refresh rate, color accuracy, contrast ratio, max nit brightness, etc. Also, monitors are a lot more expensive than I thought. I'm currently looking at 2k res, 144hz, ips, 27 incher around $450 or less. MSI and LG have some decent ones. Brand isn't important but I'm avoiding acer due to build quality. If you're shopping around for monitors, I'd avoid newegg. I've heard about bad experiences with their return policy, especially for monitors.
Example of a decent monitor: https://www.amazon.com/MSI-Non-Glare-Adjustment-Optix-MAG271CQR/dp/B07RPFZPS9
https://linustechtips.com/topic/1176609-help/#findComment-13471290
