To Freesync or not to freesync, there is the question.
PandaGab68
I heard that freesync would cap my 1070ti at max 60hz.
1. Is it true
2. Is a 120hz w/freesync better than a 120hz w/o freesync (with a 1070ti)
3. What should I be looking for or I want to play games but not at an e-sport standard haha I won't be playing shooter online so I dont need a crazy refresh rate.
Thx !!!
~(O.o)~
 R5 3600x  MSI MPG x570 Gaming EDGE Wi-Fi   Corsair Vengeance RGB PRO (black) 2x8GB 3600MHz  Zotac GTX 1070ti AMP! Edition 8GB  EVGA 750W B2  Noctua NH-D15S Chromax ‖ 2 × Be quiet!  SILENTWING 3 140mm / x Be quiet! PUREWING 2 140mm / 1 x Be quiet! PUREWING 2 120mm  Corsair 540 air (black)
1. No, unless it's native refresh rate is 60hz.
2. Subjectively, I believe so, yes. Adaptive refresh is the second best thing since sliced bread.
3.This is a very broad question, so I'll simply say; the best thing that fits your budget.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
1. No
2. If frame rates can drop below 120fps, yes
3. Freesync on high refresh rate monitor tends to not add much to the price, so I would opt for it regardless.
Desktop benching:
Even if the native refresh rate is 60hz, it wouldn't cap FPS at 60. It only goes into effect when your fps is lower than the refresh rate. at 1000 fps with a 60hz monitor, it'd still be 1000fps. If it was 40 fps on a 60hz monitor, it would change the monitor to 40hz. (iirc)
