sounds like the PC dies while it's working. You probably have a dead component.
Specs? Symptoms of shutdown?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1175845-pc-problem/#findComment-13465351
Have you tried a different cable?
Have you tried the settings of the monitor to see if it is set to sleep after a period of time?
Have you checked all cables are in correctly?
Have you tried using something like Chrome Remote Desktop on a tablet or phone to see what the PC sees regarding the monitor at this time?
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1175845-pc-problem/#findComment-13465627
i did not try different cable and i did not play with monitor setting in long time this started happening suddenly
https://linustechtips.com/topic/1175845-pc-problem/#findComment-13465842
20 minutes ago, Banoon said:
i5 3570 asus mother board
msi gtx 750 graphics card
I would guess a problem with the age of the components. If the power supply or motherboard is defective, that would explain it.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1175845-pc-problem/#findComment-13465929
6 hours ago, Banoon said:
but i have run some tests in there it dose not show anythin ..
Those tests mean nothing if the problem comes and goes.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1175845-pc-problem/#findComment-13468828
