3 minutes ago, MKSanic said:
so pc part picker says that i may need a separate mounting adapter for my motherboard and i am not sure if i need it.
https://pcpartpicker.com/user/MKSanic/saved/JFvdD3
Your list is private, can you make it public or just list the specs here?
3 hours ago, MKSanic said:
ok thx
The CPU comes with stock cooler. 212 Evo is not that much better, so you are wasting money there. If you want to buy aftermarket cooler, go for Arctic Freezer 33/34 eSports or be Quiet! Pure Rock which are in same price range and all better than 212 Evo on cooling performance and noise. For under $40 there's upgraded version of 212, the Black Edition. Also better than EVO.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
