Ryzen 5 3600 high temps with aftermarket cooler
Solved by WoodenMarker,
11 hours ago, LethoX said:if I can fit another intake fan, if I remove the hard drive thing. Do any of you know if that's possible with this case? Here's another masterpiece made in paint, to show what I mean
A front fan can be screwed in with the included long fan screws after removing the front panel. No need to remove the drive cage but it can allow for better airflow. From the user manual:
The hdd cage can be removed via screws at the back of the motherboard tray panel. https://thinkcomputers.org/corsair-carbide-series-100r-case-review/4/
Your temps seem fine already. If you want to add a fan just for extra airflow and want fan recommendations, tell us where you're shopping / located and your budget.
