Razer Viper
Go to solution Solved by minibois,
https://www.razer.com/eu-en/viper-family
So looks like the Ultimate is:
- Wireless
- 'Lighter' (5 grams lighter when not using a cable, probably same weight otherwise)
- more DPI and maybe better sensor?
- (Optionally) Has a dock to charge (because it's wireless)
- Wireless
https://linustechtips.com/topic/1174349-razer-viper/#findComment-13453153
Phisically they are the same mouse, the Ultimate has slightly improved side buttons (the same but the tension has been slightly improved), some higher specced features (Focus+ sesor, 20k DPI, 650 IPS...).
In my opinion you should get the Ultimate only if you need/want a wireless mouse, that is essentially what justifies the price difference.
https://linustechtips.com/topic/1174349-razer-viper/#findComment-13453159
2 minutes ago, minibois said:
- Has a dock to charge (because it's wireless)
Beware for the chargin dock you need to pay extra money - there is a version with only the charging cable, it's about 20$ less.
https://linustechtips.com/topic/1174349-razer-viper/#findComment-13453161
