Hi guys I'm new so if this isnt the right spot to ask let me know
I just recently built my first ever pc and was wondering what I can over clock if at all possible
Specs
Msi radeon rx 580
Msi b450 gaming pro carbon ac mobo
R5 2600
Corsair vengeance ddr4 ram (3000mhz c13)
and the psu is corsair 550w 80+ bronze cert
https://linustechtips.com/topic/1173741-help/
Yes if cooling is up to the task, I doubt that stick is rated for C13 though, C16 maybe?
Desktop benching:
https://linustechtips.com/topic/1173741-help/#findComment-13448297
Well, I think you can overclock your GPU. AMD Radeon software can do that.
Note: I'm using version 20.1.3. Version 20.2.2 is available currently as of 6th April 2020 and might have different interface.
Also very important: MANUAL TUNING OF YOUR GRAPHIC CARD MAY POSE AN EXTREME RISK OF SYSTEM MALFUNCTION AND COULD RESULT IN PARTIAL OR TOTAL FAILURE OF YOUR SYSTEM. THE GUIDE ONLY SERVE 'AS IS', AND HAS NO LIABILITY WHATSOEVER. PERFORM THIS METHOD ONLY AT YOUR OWN DISCRETION.
Open Radeon software, then click on Performance tab. If you don't have this software, please download and install.
Then, just below the performance tab, click tuning. At the tuning control, you can click manual.
Search through the Internet to get the best tuning parameters for your card. You can play with the values and try out different combination.
Do take note: Manual tuning can be very dangerous if you are not sure what is your card capability. YOUR SYSTEM MAY REBOOT UNEXPECTEDLY IF THE SETTINGS IS INCORRECT. Make sure when you are experimenting with the numbers, save all your works and minimise reading and writing data to your storage device. You might need a GPU benchmark software to test your settings if they work correctly. I use Unigine Superposition for my benching software.
Tips: One sure way to boost your performance is by increasing RAM speed.
Have fun.
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
https://linustechtips.com/topic/1173741-help/#findComment-13448311
