Is 29-32'c normal for idle on my cpu?
Solved by minibois,
11 minutes ago, KSKGAMETV said:my cpu temp runs at around 29-32'c when idle, i read a slighter higher temp was better for the cpu. (on google somewhere)
Nothing to worry about.
- Idle CPU temps don't say much at all
- As long as you are above ambient, you're good (ambient temp = temp in your room)
- there is no reason a higher temp is better for your CPU (you may have read that about SSD's)
Featured Topics
Bobzcpu ·
Posted in Power Supplies2 -
1
RZBAKA ·
Posted in New Builds and Planning4 -
1
Magnumenforce ·
Posted in Phones and Tablets2 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
5
