i've been wanting to emerge myself into Ray-Tracing for a while. I'm not to good with PCs if you are going to help try to keep it as cheap as you can it is in (AUD) any help will be appreciated. I wont be responding until tomorrow don't need to include monitors or peripherals as I have already got them. :)
https://linustechtips.com/topic/1171560-need-help-for-the-rtx-build/
I will consider increasing my budget with the cheaper one would a 1600 AF bottleneck because it would make it cheaper also forgot to mention a would like 2tb of storage my mistake thank you for making these lists and I don't really mind about modular power supplies I'm a person who prefers performance over looks. once again thank you
right then this is how a budget one would look like.
