So i have an access point connected to my router, with everything working ok. I tried to connect the ap via a new switch i got and it doesnt work. I keeps saying obtaining ip address which i asume means it isnt connected to the router. I have have tried all the ports on the switch. (this is the one https://www.tp-link.com/us/support/download/tl-sf1005d/ version 15). any help is appricieted thanks.
1 minute ago, Adimantus said:
idk i guess i bought the first one i saw. XD im not very educated in these matters. What do you mean does the link show?Thanks for the reply.
do the devices you have connected show a link up? Is there a light next to the port?
11 minutes ago, Adimantus said:
yes both ports have the lights on, the access point as well.
Do you have anouther switch you can test? Im gonna guess bad switch. You can try running some packet caps if you really want to troubleshoot
3 minutes ago, Adimantus said:
i just noticed something...the ports on the switch all have 4 pins. shoudn't they have 8?
If it was just a 10/100 switch, not all pins are needed.
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
Have you tried setting a static ip?
and if you connect a device to that AP's wifi does it get an ip and connect to the internet?
