Upgrading problem or question.
Go to solution Solved by FloRolf,
what do you mean?
What PSU do you have?
If it's modular you just have to plug another SATA Cable into the PSU and you're done.
what do you mean?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
3 minutes ago, FloRolf said:
what do you mean?
3 minutes ago, 5x5 said:
What power supply are you using? Specific model
As stated i have the EVGA 650 GQ.
I think i figured out the problem. I have added some thermal take pure plus 12 fans to my build. And i plugged them into the SATA ports. Can i plug these fans into the PERIF slot on my psu?
