Hey there!
My name is Karan and I had an old PC lying around with a core 2 duo inside but it had no gpu so I decided to get a geforce 210 and install in it.The geforce 210 worked for 5 days and I saw driver update when I updated the driver,I worked flawlessly but after a reboot it booted till the windows logo and restarted and now this happens all the time.When I boot it into safe mode it boots no problem but with the gpu it does not boot.I have tried many driver ranging from 2014 to 2016 latest drivers.
https://linustechtips.com/topic/1171146-help-needed-with-gpu/
your going to have better luck with the onboard graphics. the older drivers likely got broken with a newer windows 10 update.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/1171146-help-needed-with-gpu/#findComment-13426458
Just now, Karan Chopra said:
Can installing windows 7 solve the problem?
maybe but I'm not going to recommend windows 7 given it is end of support.
https://linustechtips.com/topic/1171146-help-needed-with-gpu/#findComment-13426465
Depending on what C2D it is, it might be a fair pair for something like a GT 730 or even 1030, but the later stretches it already.
To run Windows 10 on I can only recommend giving it 8 GB RAM and an SSD as a minimum. And even then it might be more worth for some retro build than to do modern usage with it. Most upgrades will cost more than it is worth.
About onboard graphics it really depends on what and if the board has.
If you really, really want to use that, keep the GT 210 in (assuming it works) and put XP on it for older games. That might be the best use of it, although I can't really recommend it.
https://linustechtips.com/topic/1171146-help-needed-with-gpu/#findComment-13426573
