- Download MSI Afterburner and Unigine Valley Benchmark.
- Open up MSI Afterburner and max out your Power Limit
- Increase the core clock by a bit at a time (25MHz at a time) and same goes for memory.
- Then stress test your GPU (run Unigine Valley Benchmark) for 10 to 15 minutes.
- If the application doesn't crash, then your overclock is stable but if Unigine Valley Benchmark crashes, then your overclock isn't stable.
- If your overclock is stable, keep increasing the core/memory clock.
- If your app crashes, you have two options: either add more voltage or decrease the core/memory clock.
- You can also modify your fan curve in MSI Afterburner (Settings > Fan > Enable user defined software automatic fan control) to your preference.
- Keep your temps in check, try to stay under ~80°C when running the benchmark.
- Check for GPU artifacting as this problem occurs when your memory clock is unstable or too high.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1169541-oc-guide/#findComment-13412343
You should be shooting for 1425-1500mhz depending on your card, but what ^^^ said is very good information.
i use F@H so I normally run furmark for 30 mins to make sure temps stay in check and everything’s stable, but if your just gaming unigine valley works great
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1169541-oc-guide/#findComment-13412377
The above is good for starting, but I wouldn't say it's the final determination of a stable clock.
I was able to get +100 core and +675 memory in running Valley for 30+ minutes without crashing. Crashed in 10 minutes playing GTA V. I think you need varied workload to really stress an overclock before saying it's stable. Also would only crash quickly at certain parts of the map; others would run for longer without crashing. Temps were always below 70 C.
Turns out the core clock is what was most sensitive in my case and anything over +75 core would crash after 10-15 minutes gaming. Additionally, I saw essentially no FPS gains above +300 memory using Valley and free cam. Backed off to +275 memory and kept it there.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1169541-oc-guide/#findComment-13412436
