Ok this is mostly curiosity now because I ended up switching, but a Linus video on the 5600xt made me think things again. the horror.
I just had to return an XFX 5700xt THICC III ULTRA due to 3 solid weeks of black screens, crashes, and other software issues.
I had zero ability to overclock or even mess with ANYTHING (stock settings ONLY)
AND the card struggled to handle even Destiny 2 @1080p/144 on "high" (NOT maxed.) It straight up would not even allow me to open Rocket League... Blah blahBlahblahblahBLAHHH!
So the question is thiiiiis,
HOW ON EARTH are you guys able to actually use the new Radeon 2020 Software?!
I tried everything! I had pro's help me out! And I AM a pro! (Ok sorta pro.) Just, endless software issues even after 3 patches from AMD (who have been trying to fix this for months) and apparently there were a huge number of returns for the same reason, specifically for most versions of the 5700xt.
Just a quick note, I was also having similar issues with my old R9 390 8gb the moment Adrenaline 2020 released. the 2019 version didn't have any of these issues. This is actually what prompted the upgrade in the first place. Bleh.
System:
Msi X270 Tomahawk Arctic (xmp + gameboost on)
I7-7700k @ 4.8Ghz
32gb Corsair ddr4 @3200
Nvme w/ win10 pro 1909
5700xt  Aorus 1080ti
I was really stoked about this line-up. At least I Lucked out and found a 1080ti for $350, got it working inside of 2 hours. (Though if I attempt to over-clock, it crashes pretty quick.)
Is it my system? Is it too old? What did I do wrong?
idk how to get rid of these spoilers, whoops
https://linustechtips.com/topic/1169003-help-sorta/
what power supply are you using? specific model and wattage.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1169003-help-sorta/#findComment-13407528
Whoops,
RaidMax RX850w 80+ Gold I figured there mightve been an issue there, I ran two separate cords instead of using the two ends on one cable. This didn't change anything. As far as I can tell all of my tests on the hardware checked out. The adrenaline software just... didn't wanna. But any input is appreciated!
https://linustechtips.com/topic/1169003-help-sorta/#findComment-13407537
4 hours ago, Spork750 said:
Whoops,
That card is shit it's shit in temps and even worse in power delivery
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1169003-help-sorta/#findComment-13408133
