So I have one of EK's aluminum custom loop kits and ive run out of their special additive. Has anyone just used plain distilled water without any additives and did you have any issues with it? how long were you able to go without growth, etc?
Ryzen 7 1700 @3.8GHz | Asus X370-F | 32gb Corsair Lpx | Nvidia Rtx 2070 super | WD black 256gb nvme | Crucial mx300 1Tb sata | Fractal Design Meshify C | Corsair RM750i | Noctua Nh-u12a | Samsung 1440p 144hz VA
Certified Noctua fan
https://linustechtips.com/topic/1168828-using-just-distilled-water-in-loop/
I have. (well i used biocide)
The below images are after 5 years of just distilled and some biocide prior to cleaning, after cleaning pritty much everything u see thats blue/green was bare copper underneath.
Its my old since replaced 780 Classifed card and block.
My CPU block was also in a similar condition, i still use it however and all is fine.
IMG_20190320_124256.thumb.jpg.6c8be62721d802982ff147ca2b544e31.jpgIMG_20190320_124302.thumb.jpg.357963eb5aa56c5d24d333395820478c.jpg
The main takeaway, use a corrosion inhibitor.
I never had an issue with biological buildup as i used a biocide, nor did i have any other buildup or gunk beyond the usual white residue from long term soft tube use mainly on the inside of the tubing itself. It also performed just fine the entire time, this was only torn apart as i was upgrading.
So u can use just distilled , but i would highly recommend u add corrosion inhibitor and biocide when u get the chance.
Mayhems do both, its what i use.
My loop currently runs distilled + Mayhems inhibitor + biocide.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
I’d try not to be so cheap and just order something to add to the water. Only 13 bucks normally to treat an 89 cent gallon of distilled. More then enough for the system.
With aluminum it will very easily have build up, you need corrosion inhibitors and biocides found in dedicated fluids.
I use Antifreeze - natural biocide, corrosive inhibitor (specifically use Prestone 50/50 with their patented Cor-Guard) and stupidly cheap.  Ive filled 3 loops and have about 5 more to go before the bottle is empty....$10 bucks so basically $1 something to fill a loop with 3 radiators.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
