What Do I upgrade first
Go to solution Solved by TheMcFunnel,
3 minutes ago, dizmo said:
PSU, then RAM, then GPU.
thank you but why the psu first
Hi
I was wondering what to upgrade first because I had just upgraded to a Ryzen 5 1600 AF from my Pentium G4560
GPU: Asus GTX 650 Ti Boost 2GB
RAM: Crucial DDR4 2400Mhz No Heatsink or RGB :( dual channel 2x4GB sticks
rest of my system:
Ryzen 5 1600 AF 3.2Ghz
Unknown Supplier it's powder coated PSU 750w silver
Gigabyte B450M-H (Ryzen 3000 out of the box)
128GB WD green SSD
1TB WD blue HDD
and some case
any help would be appreciated :)
https://linustechtips.com/topic/1168446-what-do-i-upgrade-first/
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
It's likely low quality. A PSU failure can destroy everything else in the system.
RAM next because there's no point in buying a GPU this close to the release of the new ones.
Just now, Fr3ddy said:
Also firstly I'd upgrade the gpu because most gpus with that cpu would not even get close to 750w and 8gb of ram although not ideal is usable
There is far more to a PSU than simply wattage.
yeah the psu has got Yucky mustard cables
so what wattage should my psu be
550w would be fine, 650w if you want a little headroom.
Check the LTT PSU Tier list for quality units.
However my PSU has lasted me two years and I did notice my PSU has silver certification so what RAM speed should I have
2 minutes ago, TheMcFunnel said:
yeah I just like playing rainbow six siege
I just want to get the best performance without breaking the bank
This should help then https://www.google.com/amp/s/www.systemrequirementslab.com/cyri/requirements/tom-clancys-rainbow-six-siege-beta/12864/amp
Silver certification means nothing in regards to quality or how long it'll last. It's simply how efficient the PSU is. I'd still replace it.
I would aim above or on par with recommended settings because it is a multilayer fps and requires precision
PSU ➡️ RAM ➡️ GPU
You want to get a good quality PSU, your's is likely not very good at all, brand and efficiency does not equal quality.
Refer to this list:
I recommend Tier B or higher, 550W is plenty.
For Ryzen get a dual channel kit of 2x8GB CL16 3200MHz or faster.
GPU budget and options can be re-assessed once those first two items have been upgraded.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
3 minutes ago, JM21 said:
PSU ➡️ RAM ➡️ GPU
Refer to this list:
Oh Ok yeah I know my GPU isn't gonna happen for a long time with COVID 19 lurking but the PSU and RAM will be upgraded quickly
