8 minutes ago, ThriversCap said:
Im making a new build and want to know the difference if there is one between these two cards becuase one fits the aesthetic of the build.
One is a loud AMD stock cooler, the other (the Evoke) is a pretty good cooler on the same card.
Just gotta make sure you get the fixed version of the Evoke, but I am not sure how you would go about doing that. To be honest, I would expect all of them to be fixed at this point though.
https://linustechtips.com/topic/1168336-help-with-compairison/#findComment-13401953
If I'm correct, the second one isn't XT
Just 5700
https://linustechtips.com/topic/1168336-help-with-compairison/#findComment-13401968
Just 5700
Ah yes, good eye! Missed that rather important detail.
The RX 5700XT is quite a bit better than the RX 5700 (not XT).
https://linustechtips.com/topic/1168336-help-with-compairison/#findComment-13401978
