My Possible Build
Go to solution Solved by Meganter,
This is the parts list I am planning on using for my build I am trying to keep my price below 1800$(US).https://pcpartpicker.com/user/Jacobf52004/saved/#view=M49Czy
Please leave feedback on the pcpartpicker page and look at the description before looking at the list or while looking at the list.
Thank you for taking the time to read through my post and parts list.
https://linustechtips.com/topic/1168298-my-possible-build/
https://linustechtips.com/topic/1168298-my-possible-build/#findComment-13401637
This list can't be modified so it's cumbersome for everyone to work on it. Just use the BB code and paste it in. That way the partlist can be modified.
Your cooler is pretty expensive, the PSU is a bit overkill, the Acer monitor is 1080p and only 75Hz, if you have a Win7 or Win8 key, it will work and you don't need to buy it. I find the mainboard a bit expensive for its performance.
P.S.: Why Ryzen 7? You'll gain little to no noticable performance in games. If you don't need the additional cores, save the money and go with Ryzen 5.
P.P.S.: This is what I'd suggest. There's a great deal on a pack with the Corsair K55 and their Harpoon mice. If you don't like it, go with your choice, and it's $35 on top. You can save the money for the 3600X and just go with the 3600 and OC it. They're again just differently binned.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($174.99 @ B&H)
CPU Cooler: be quiet! Dark Rock 4 CPU Cooler  ($69.90 @ B&H)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  ($111.99 @ B&H)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($83.99 @ Newegg)
Storage: Western Digital SN750 500 GB M.2-2280 NVME Solid State Drive  ($69.99 @ Newegg)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.98 @ Newegg)
Video Card: Asus GeForce RTX 2080 SUPER 8 GB DUAL EVO OC Video Card  ($729.99 @ B&H)
Case: NZXT H510 ATX Mid Tower Case  ($69.99 @ B&H)
Power Supply: Corsair RM (2019) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.97 @ Newegg)
Case Fan: be quiet! SilentWings 3 pwm 59.5 CFM 140 mm Fan  ($21.90 @ Amazon)
Monitor: MSI Optix G27C4 27.0" 1920x1080 165 Hz Monitor  ($199.99 @ Newegg)
Keyboard: Corsair K55 + HARPOON RGB Wired Gaming Keyboard With Optical Mouse  ($59.99 @ Best Buy)
Total: $1789.57
Generated by PCPartPicker 2020-03-24 14:30 EDT-0400
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1168298-my-possible-build/#findComment-13401641
