Hi guys I Cant seem to get into BIOS anymore.
There is no splash screen and when i hit delete to get into bios there is nothing but a black screen. I have tried clearing CMOS (battery, jumper, you name it). When I do it takes me to a Bios setup utility. when i run it, it is the same black screen. Windows works normally. Everything is detected, and the RAM is okay. I used it in a friends build, everything was ok.
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
https://linustechtips.com/topic/11666-urgent-help/
Did you try it on a different monitor to see if the bios works?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/11666-urgent-help/#findComment-124300
Does your motherboard have a fast boot feature?
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/11666-urgent-help/#findComment-124336
I had this problem before and it had to do with my mechanical keyboard because of the 20 N-key rollovers, I just had to update my Gigabyte Motherboard BIOS to a UEFI and it was all fixed. So if you have a mechanical keyboard with a large N-key rollover then maybe you should upgrade your BIOS. A quick fix for that for me was just grabbing my parents or brothers membrane keyboard and accessing the BIOS from there to get it updated because all the membrane keyboard will work 99% of the time. Just something to think about
https://linustechtips.com/topic/11666-urgent-help/#findComment-124671
See i would upgrade my BIOS, but ASUS has the drivers messed up on their website! Also, I have tried other GPUs and Monitors, so its from the motherboard.
https://linustechtips.com/topic/11666-urgent-help/#findComment-127180
Specs: Fx6100
Mobo: Asus m5a97
Graphics card : XFX RADeon HD 6850
RAM: PAtriot G2 8gb 1600mhz
https://linustechtips.com/topic/11666-urgent-help/#findComment-127184
I've tried everything, still black screening. Ran my mobo on my dads pc, same problem. its my mobo.
https://linustechtips.com/topic/11666-urgent-help/#findComment-128694
Strange problem, Windows works normally?  If Windows boots. Try to force the motherboard to not boot windows, disconnect all ssd and hdds and make it Say that "boot is missing" If this message comes up it might be your monitor that is too slow to receive a signal before booting Windows. If this is the case, try hammering "DEL" after you push the power button on the PC and see if the UEFI comes up.
https://linustechtips.com/topic/11666-urgent-help/#findComment-128848
What version of windows are you running? I have heard that in windows eight it makes it so that you cannot get into the bios unless you change some setting inside of windows. (Not sure if true.)
The first step to insanity is believing in your sanity.
https://linustechtips.com/topic/11666-urgent-help/#findComment-128931
Run this in cmd: "shutdown /s /full /t 0" (without the quotes) to perform a full shutdown and to see if your bios screen shows.
https://linustechtips.com/topic/11666-urgent-help/#findComment-129199
Yo Dude, I would try a wired key board, just hook it all up before ya start the boot and cross ya fingers...Hope all goes well. Stupid computers! Why have they made them so dam complicated, its just zeros and ones but humans will find a way of  making the easiest things complicated, maybe just maybe someone is making money from this?? Hmmm...
https://linustechtips.com/topic/11666-urgent-help/#findComment-130586
if all else fails download the very first bios released from asus for the m/board and flash that
CPU: i7 3770k 4.5ghz M/Board: Sabertooth Z77 GPU: Asus Gtx 560 Direct CUii OC RAM: 2x4gb Corsair Veangance PSU: Corsair CX600 Cooler: Custome Water Loop With Gentle typhoon 1850rpm fan, Single 120mm Rad, XSPC Raystorm CPU Block
https://linustechtips.com/topic/11666-urgent-help/#findComment-130912
I just got the asus vg248qe monitor and i cant seem to get the hz past 60 this monitior max is 144hz witht he dual link dvi cable but i cant use that since i have it connected to my laptop witch is the asus g75vw. i just want to get to 120hz since i wont be able to connect through the dual link dvi to get the 3D/144hz. Any ideas would be great
https://linustechtips.com/topic/11666-urgent-help/#findComment-131302
I have tried many keyboards, mechanical, ps/2, usb, evrything
https://linustechtips.com/topic/11666-urgent-help/#findComment-132798
my guess, remove power cord, take out battery, let the computer sit for about 3 minutes, hold the power button to drain any remaining power for at least 15 seconds, don't put battery back in, put the power cord in and power it on to see if it works. If not just be patience and see if the bios pops up after a couple of minutes.
"You are who you choose to be.....Choose"
See my Profile for my
https://linustechtips.com/topic/11666-urgent-help/#findComment-133630
