Dell XPS Problem
Go to solution Solved by Pickles von Brine,
So I have had a Dell XPS  M1710 since it came out. Got it from my dad in 2007 but there is a problem now. There are some green artifacts on the display (also show up on external monitor) Dell expert told me that it is a GPU failure. I am just wondering, is it worth buying a new GPU for $12 and install it myself or to buy a new laptop. I have been a huge fan of Dell laptops and really don't want to get rid of this one. Oh and also, if I apply pressure to the palm rest the artifacts go away but come back when I let go
Make sure to quote me @Meowster  so that I see your reply
I love my job, being a sysadmin. It's very fun
https://linustechtips.com/topic/1166386-dell-xps-problem/
I'd start by opening up the laptop and seeing if something is loose/partially disconnected.  If you can push on the palm rest and the issue goes away that might be the case.
If the GPU is serviceable and you can find a replacement for that cheap you might as well give it a try.  Otherwise, it's a 13+ year old device and might just be time to replace it.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1166386-dell-xps-problem/#findComment-13387970
this is a laptop right?
make sure you can actually remove your GPU, I know some of the older laptops they soldered to the MOBO
homeofmew (homeofmew#1337)
[ | folding@home | F@A Extreme Over Clocking | Bionic | ]
Bachelors of Science in Mathematics, University of Houston
https://linustechtips.com/topic/1166386-dell-xps-problem/#findComment-13387977
Be sure to @Pickles von Brine if you want me to see your reply!
Stopping by to praise the all mighty jar Lord pickles... * drinks from a chalice of holy pickle juice and tossed dill over shoulder* ~ @WarDance
3600x | NH-D15 Chromax Black | 32GB 3200MHz | ASUS KO RTX 3070 UnderVolted and UnderClocked | Gigabyte Aorus Elite AX X570S | Seasonic X760w | Phanteks Evolv X | 500GB WD_Black SN750 x2 | Sandisk Skyhawk 3.84TB SSD
https://linustechtips.com/topic/1166386-dell-xps-problem/#findComment-13387981
15 hours ago, Lord Xeb said:
Bought a new one, should be coming on Tuesday :)
https://linustechtips.com/topic/1166386-dell-xps-problem/#findComment-13389620
