Ubuntu 19.10 Shared wifi over ethernet. LAN cant connect to the client. How to fix?
Solved by Windows7ge,
At least on Windows sharing an Internet connection through the PC is like 1/2 NAT where the Guest can make a connection out to clients on the Host subnet but connections coming back need to be translated (NAT). Linux may be different but usually people only share their Internet connection when they want a guest to have Internet access not a connection to the parent subnet so there's a chance here that what you're asking isn't possible.
I'd try to find a corner in a different room where you can put the machine. One you can easily run power and Ethernet to.
