I'm staring to get some kind of panic over loosing information because of drive failure.
i currently have a machine with decent specs, not up to date but works good.
CPU: i5-3570
16 gb ram ddr3 1333MHZ
p8Z77 mb
SSD1: 250GB (os)
HDD1: 500GB
HDD2: 250GB
2060 GPU (SHOULD NOT MATTER)
I really don't want to get a NAS, but I'm not closed mind into not getting one, just that the computer is always on so i don't see why get more HW.
what would be the best way into getting some redundancy and maybe write speed? i am willing into getting new HDD's (2 or 4).
do i need virtualization of some kind? or just software?
I'm a bit lost.
Thanks,
https://linustechtips.com/topic/1166140-best-store-solution/
CPU: i5-3570
p8Z77 mb
SSD1: 250GB (os)
HDD1: 500GB
HDD2: 250GB
I'm a bit lost.
Thanks,
3-2-1... 3 backups, 2 locations, one of them offsite
That's usually what I hear for data backup if you have stuff you are really worried about losing.  Now, most people don't do this (myself included) level of backup, but even just an external hard drive you back up important files to once a month and keep in your house somewhere is better than nothing.  You could even get a single drive with a couple TB of space and install it into your existing machine, then just copy data from the other drives over to it as backup.  There are a number of different ways to backup stuff you're really concerned about.  Depending on total size of files renting cloud storage space may be another option.
A NAS with RAID configured is the better option for home, but depending on if you are looking for just archival capabilities or daily read/write/working performance will determine how that gets configured.  Not my area of knowledge though, so I can't really recommend anything beyond just saying that it's an option.  The benefit of NAS vs. your existing always on computer is that if your PC gets damaged for whatever reason (power surge, PSU failure, water, whatever...) then your data is not physically located in the same box and has a lower chance of being lost.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1166140-best-store-solution/#findComment-13383819
Get rid of the two smaller HDDs. They're likely super old. Replace with a 1TB HDD.
Depending on what it is, back it up to the cloud.
You can also get an external HDD and have the internal HDD back up to that.
Then you'd have 2 copies locally, and one copy off site.
If you're super paranoid you could make another copy, but honestly I think that's a little overkill for most situations. Generally the cloud and another physical is good enough.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1166140-best-store-solution/#findComment-13383833
I use cheap WD Passports for backups. I have gotten 1 and 2 tb drives of the price of a game($60 for 2tb now in US).
The next one I buy will be 4tbs. They are $129 now but I have seen them go for around $70 on Black friday.
I don't use special software to copy files. I just use the mouse.
I have never had one fail yet but they are only spinning when I need something from them and that is rare.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1166140-best-store-solution/#findComment-13383936
