On 3/18/2020 at 9:24 AM, RusselTheMuscle said:
Which of these cases provide better air flow? Cooler Master TD500 Mesh or Cooler Master MB511?
Since they have the same prices, I want to know the difference between the two. Thanks.
Theoretically they will both have basically the same airflow, since I believe cooler master uses the same fans in both cases. Both internal frames are based on the masterbox too, so just pick whichever you like the look of better.
https://linustechtips.com/topic/1165971-better-air-flow/#findComment-13385909
