Hey, so I am new the the pc world ( gaming) and I went and bought a pc but it needed a power supply and a graphics cars so I purchased both. The power supply swapped with no problem. With the you though it went in fine but after first boot up and me trying to install the drivers that’s were I had a problem. It put in all the specs needed on nvidia’s website and chose the correct driver. It went all the way through to systems check (not sure if this was the correct name) then it said the driver is not compatible with the version of Windows. I searched the internet or similar problems but it only said to make sure windows is up to date. I updated windows but still had the problem. Please HELP
https://linustechtips.com/topic/1164732-help-used-gtx-690-having-problems/
Can you please list your PC components? What PSU are you using?
CPU: i7 8700K (5.1 GHz OC). AIO: EVGA CLC 280 280mmGPUEVGA XC2 Ultra 2080Ti. PSU: Corsair RM850x 850W 80+ Gold Fully Modular. MB: MSI MEG Z390 ACE. RAM: 32GB Corsair Dominator Platinum RGB (3600 MHz OC). STORAGE: 1TB Samsung 970 Evo Plus M.2 NVMe, 2TB Samsung 860 EVO, 1TB Samsung 860 Evo, 1TB Samsung 860 QVO, 2TB Firecuda 7200rpm SSHD, 1TB WD Blue. CASE: NZXT H510 Elite. FANS: Corsair LL120 RGB 120mm x4. MONITOR: MSI Optix MAG271CQR 2560x1440 144hz. Headset: Steelseries Arctis 5 Gaming Headset. Keyboard: Razer Cynosa Chroma. Mouse: Razer Basilisk Ultimate (Wireless) Webcam: Logitech C922x Pro Stream Webcam.
Operating System
    Windows 10 Pro 64-bit
CPU
    Intel Core i5 2500 @ 3.30GHz    34 °C
    Sandy Bridge 32nm Technology
RAM
    8.00GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
    Dell Inc. 06D7TR (CPU 1)
Graphics
    2779 (1920x1080@60Hz)
    Intel HD Graphics (Dell)
Storage
    1863GB Seagate ST2000VM003-1ET164 (SATA )    34 °C
Optical Drives
    No optical disk drives detected
Audio
    High Definition Audio Device
I have a 500w PSU
