What I want to know if there is a difference between a normal 2.5 ssd or a M.2 ssd
the specs are almost the same and also the same price
Kingston A400 120G Internal SSD M.2 2280 SA400M8/120G
PNY CS900 120GB 2.5” SATA III Internal Solid State Drive (SSD)
is it the same? do I get any benefit?
https://linustechtips.com/topic/1164326-ssd-help/
3 minutes ago, Goliath002 said:
ok so there is no difference after all is the same, it's just the way it connects
Right?
yea exactly the same performance.
Also both of those are very low end ssds, so you might want to try to get a better sd if you can.
https://linustechtips.com/topic/1164326-ssd-help/#findComment-13368556
