Hello, I want to build my first pc (gaming) but I don't have a high budget ( 400€ - 430€ germany). I've spend a lot of time searching and comparing pc pieces and I think I have found good ones. I'm not an expert (more a noob) so could you please look if my chooses are good. I do have a Pc part picker list but there are some pieces that don't show up. So I've made a web where there are all the exact components. I just buy from amazon because I had very good experiences with the returns. I want to play minecraft with this pc and I have now a laptop with the intel i3-6006u with integrated graphics card intel hd 520 and it runs Minecraft between 50-60 fps but there are often frame drops and if there are a lot of chunk updates like Redstone the fps drops to 0-10. And Minecraft is a game that uses more the cpu than the gpu. So i think that the ryzen 3200g is better than the intel i3-6006u and it will have more fps.
I3-6006u vs ryzen 3 3200g: https://cpu.userbenchmark.com/Compare/Intel-Core-i3-6006U-vs-AMD-Ryzen-3-3200G/m214467vsm824486
Video: https://www.youtube.com/watch?v=oC6CxTxat74
This is minecraft on ryzen 3 2200g: https://www.userbenchmark.com/PCGame/FPS-Estimates-Minecraft/3776/441833.441832.0.0.0
https://de.pcpartpicker.com/list/TcwzHB
My website where are all the components: https://spaceagle17buildsapc.blogspot.com/2020/02/my-pc.html
Thank you guys a lot!
https://linustechtips.com/topic/1163897-first-pc-build/
i think that would do just fine for minecraft
as you said it already minecraft is more on cpu then gpu
so a good cpu is crucial and AMD is good for gaming these days.
myself i'm never a big fan of integrated gpu's and i'll always put in an extra gpu but this is just because i play a bigger variation of games.
just do yourself a favor for the future alsways make sure your psu is able to handle it if you add a gpu
and your case has the room for it.
Could save you some euro's in the future if you change interest from minecraft to who knows what game
currently rocking
AMD Ryzen 9 5950X 32 GB of corsair vengeance RGB ram and hoping to get my 6800XT soon!!!!
https://linustechtips.com/topic/1163897-first-pc-build/#findComment-13364669
So is evga 100-W1-0500-KR (49,5€) good or should i take the 100-BR-0500-K2 (48,9€) ?
https://linustechtips.com/topic/1163897-first-pc-build/#findComment-13364720
6 minutes ago, SpacEagle17 said:
So is evga 100-W1-0500-K3 (49,5€) good or should i take the 100-BR-0500-K2 (48,9€) ?
well sadly i can't read german, i do understand it if you would talk to me (the advantages of being native dutch)
but make sure it has the 6/8 pin connector for the graph card
if needed i can look up the differences when i'm home.
but from a quick peek at the connectors i think both should be fine.
currently rocking
https://linustechtips.com/topic/1163897-first-pc-build/#findComment-13364746
https://linustechtips.com/topic/1163897-first-pc-build/#findComment-13364835
5 minutes ago, SpacEagle17 said:
I've researched that the fps differences isn't so high like 1-8 and here the ryzen 3 3200g costs 93€ and the ryzen 5 2400g costs 165€. https://www.youtube.com/watch?time_continue=112&v=GFM7m3FF5Zc&feature=emb_logo
right, i've done some research as well and you are right, the difference in gpu performance isn't huge. the big difference is in cpu performance. but if the 2400 doesn't fit your budget, yes, go for 3200. what's your country by the way? pcpartpicker has versions for many countries.
https://linustechtips.com/topic/1163897-first-pc-build/#findComment-13364857
Germany and thanks a lot
https://linustechtips.com/topic/1163897-first-pc-build/#findComment-13364860
2 minutes ago, boggy77 said:
 so it's actually 137, not 165
Yes, I know but I buy just from amazon because i have good experiences with amazon returns and bad experiences with the returns of other companies.
https://www.amazon.de/AMD-RyzenTM-RadeonTM-VegaTM-Grafikkarte/dp/B079D8FD28/ref=sr_1_3?__mk_de_DE=ÅMÅŽÕÑ&crid=1DFHC4SSQRXSM&keywords=ryzen+5+2400g&qid=1583932688&sprefix=ryzen+5+2400%2Caps%2C200&sr=8-3
https://linustechtips.com/topic/1163897-first-pc-build/#findComment-13364890
