So I recently got a new case, 'corsair 680x', which comes with a lighting node pro and 4 fans (3 ll120 + 1 120 non rgb fan). The lighting node worked fine at first glance, but I didn't have enough pwm connectors, so I bought an additional splitter.
I installed the splitter and you guessed it, the entire pc broke the f down. I can't play games because it will just randomly lose all ethernet connection and then the screen will just freeze. Discord has the same issue but less frequently. My ll120 fans don' t light up anymore and the lighting node pro isn't detected by icue software either (they do spin though). The gpu usage tends to have major changes over time while idle(even yt vids get it to 70% for some reason) and disk usage for some reason as well. Windows will often just have a disgustingly long delay between action and what's being displayed and it's just unusable in general.
I have no clue whatsoever on what has caused this, how it happened or if these things are even related to eachother.
If you're somehow able to help me please do, Thanks in advance.
https://linustechtips.com/topic/1163735-lighting-node-pro-and-other-weird-stuff/
What did you plug into the splitter and what header on your motherboard did you plug it into? This should not cause the issues you are describing.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
I plugged the 3 ll120's and the cpu cooler fan into the splitter and plugged the splitter into the cpu fan header since gigabyte claims it to be a universal standard.
check if theres a reset button on the node. click it with a pin if you can.
update firmware as soon as it is detected.
but seriously icue is so broken mine is broken rn and i cba to fix all my rgb is frozen and when i open it it crashes lol
As in a 4-pin PWM splitter? So 4 fans are connected to 1-splitter that is going to your CPU fan header, if so only plug the CPU fan into the PCU fan header, remove the others and plug them into a different system fan header and try again. I'm assuming the the RGB for the LL fans are connected to the Lighting Node Pro with the power connector and USB 2.0 connectors attached.
iCUE can be a fickle b*tch that is for sure...
My Builds:
MEGA Desk Build
There is a reset button, but it's not really doing anything
yes, that's correct. I've now plugged them in a different spot. The fans are lit now, but it's still not being detected even after pressing the reset button.
As in iCUE does not detect the RGB?
My Builds:
MEGA Desk Build
1 minute ago, Borat said:
is doesn't detect the lighting node as a whole
Mine has done that sometimes as well, double check your connections, next step is the annoying issues with iCUE, if issues persists I would uninstall iCue and re-install.
My Builds:
MEGA Desk Build
I've done about 5 times already but luck doesn't seem to be on my side.
So I've found the solution to the weird gpu usages, it was caused by radeon relive. That is solved now and I guess the lighting node is just an issue that will be solved later. So thanks for your help, but I think I could continue with what I have now based on what you've told me.
That's good, yeah random bloat-ware can cause problems in some PC's for no apparent reason. The iCUE one is annoying though, I had a 2-week period earlier this year where it did not detect my Node as well. Multiple re-installs, nothing did the trick, then one day it worked again, no changes made, and has ever since.
My Builds:
MEGA Desk Build
I guess corsair can step up their game when it comes to software.
