DDC or D5 they both hum while running. The faster the speed the greater the hum.
CPU | Intel i9-10850K | GPU | EVGA 3080ti FTW3 HYBRID  | CASE | Phanteks Enthoo Evolv ATX | PSU | Corsair HX850i | RAM | 2x8GB G.skill Trident RGB 3000MHz | MOTHERBOARD | Asus Z490E Strix | STORAGE | Adata XPG 256GB NVME + Adata XPG 1T + WD Blue 1TB + Adata 480GB SSD | COOLING | Evga CLC280 | MONITOR | Acer Predator XB271HU | OS | Windows 10 |
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13358130
Personally have noticed using both, DDC pumps tend to run louder than d5s. If I have the option I'll always choose a d5. Can't say for sure as I haven't seen every d5 on the market, but DDC tend to be more compact as well. Works great if there's clearance issues. Even if space is a limiting factor.
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13358144
Well I got a replacement pump sent to me. The old one if I put it to 55% was silent. This one is always producing some form of a hum. The loop was just refilled yesterday but wasn't running much until now. That's why I'm wondering if it might be just some trapped air bubbles. Or maybe I just have the pump mounted too tightly? It's on a distroplate. This is a video of how it sounds.
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13358242
Yea I know ddc is louder than D5. It could very well be that it's cause it's an open air case. This is a new pump, was not run dry at all. My last one if I put it at like 55% it was silent. So not too sure whats going on.
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13358247
sounds normal to me
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13358260
On 3/9/2020 at 8:50 AM, ChrisZH said:
Is there a way I can get rid of the little bubbles that the pump is sucking in and possibly stuck on the impeller?
Crank it to 100% for 10-20 seconds... drop to 40-50 for 20 seconds... do that for 5-10 minutes... then crank it to 100% and tip the case forward, back, left, right.  Thrn just let it run at 100% for a while and it should get the rest out over night
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13363623
Did you hear the video, that sound is annoying and it's like that at 50% speed
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13363670
It doesn't sound loud in the video. My response was to getting out the air. Ddc pumps in general are louder than d5s. You sacrifice sound and a setup that is cooled by the loop for more head pressure and smaller size.
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13363678
Yea I know this, just makes me scratch my head because the same brand pump I had before was silent at the same percentage speed.
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13363760
They are still two different pumps and your other one was defective. So it might not have been spinning at the right rpm or even at all.
If you can't take the noise get a d5. Alternatively you can play with the speed. Certain speeds can cause resonance with other items in the machine that make it louder than it would be otherwise. So try increasing the speeds slowly and see if it quiets down.
https://linustechtips.com/topic/1163137-ddc-pump/#findComment-13363832
