Pls help
1 hour ago, theAnxious1 said:https://pcpartpicker.com/list/BpFVQZ
So. I installed windows 10 on this pc. Installed all the drivers needed from MSI. But i dont get any sounds. I basically tried everything but nothing worked. At one point i did get sound but after pc reboot it disappeared. Guys pls help me and treat me like and idiot (give me step by step solutions) because my knowledge in IT is very bad. Thanks for your time and effort
On device manage under sound,video etc.. i get this
in most youtube videos everyone had Realtek hd audio or something similar.
Go to Control Panel / Hardware and Sound / Sound, and check what output is selected as default for playback. You should have your motherboard audio selected. Make sure you are plugging the Speakers on the right place on the back of your pc.
