GPU Temps decrease after removing my case's side panel, is it 100% caused by bad airflow ?
I've got a Gigabyte 2080ti Gaming OC and a i7 9700k with a dark rock pro 4 in a Meshify C case. My CPU temps are normal (never gone above 60c), but GPU goes up to 85-87c when the glass side panel is closed. When I remove it, I get around 72-75c I've got 5 case fans, 4 intake and 1 exhaust... If I'm correct.
Few photos would help (different angles towards back and front so can see if fan direction is okay); and if the gpu is mounted vertically or not etc.
Other than that its normal for temps to drop without side panel even with good flow, but how much depends on a number of things.
Edited by Bartholomew
Removed incorr3ct brainfart of me regarding psu fan direction
Is the psu mounted correctly with fan down (and not up, blowing up heated air into gpu) for example.
PSU is mounted correctly, GPU is horizontal. Excuse the cable management, but I've been taking some things apart (after the temps have been acting weird) Here's a picture - I've reached the point where I genuinely hope I've done something wrong, instead of just having screwed up hardware.
The cable mgt is fine for experimenting (and wont make much difference).
Id experiment with changing top mounted left (in picture) fan to to exhaust (and temporarily disabling to top mounted right fan), focussing more on front-to back flow without so much turbulence.
Try moving the lower front intake a litlle if possible, so it jets more flow under the gpu where the gpu intakes.if it fits id try moving the top mounted right to the front panel.
I think your hw is fine, just needs a little experimentarion on how to get the best flow thats all.
Do check that the fans are oriented the way you think (flow direction), usually theres a little arrow on the plastic somewhere (alternatively usually the exhaust side is where the frame is to hold the fan in the center, intake side is were yiu can move the center with your finger to rotate)
Honestly with the size of this case... I would even consider going non-traditional and Flipping the flow. So top and rear top would be intake,  front and top front would be exhaust . The problem with that case is with the size and distance between the psu shroud and gpu it is creating a heat pocket that the air can't really circulate. So I wonder if flipping the flow around will allow the front fans to pull that heat out of that area. Your cpu temps would be largely unaffected, but it would make sure you are moving the heat away from the GPU.
*edit* that is why removing the panel works. As it stands right now that bottom right fan is just blowing the heat into that bottom corner by the PCI covers. The heat is just creating a vortex there since it doesn't really have much room to flow. So when you open the side panel the heat is about to splash against the back and escape out the side of the case. With the panel on it just stays there.
2 hours ago, bishopsdx said:
You can add an intake bottom fan!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Removing the side panel or adding another intake shouldn't make that much difference, since I got told that airflow honestly don't matter much as long as the cooling itself can handle temps no matter. So an AiO for the gpu is the only thing that you can do.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
It looks like you're using the stock case fans for front intake which aren't particularly powerful.
Are you able to shift the hdd cage back and use 3 front intake fans? I'd recommend using the NF-P12's for front intake in the lower positions. You can move the other stock fan to the top near the rear as exhaust.
