No AMD? in that case 1650s (maybe) - 1070 You don't want 40fps.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
3 minutes ago, Ron12777 said:
No AMD
You're limiting yourself fairly hard there.
RX 580's are very cheap when used, and they perform very well.
22 minutes ago, Ron12777 said:
No AMD.
That's not a very good decision, unless you have a compatibility issue I would fully recommend a used RX580, you get super reliable 60fps gaming (especially in 1080p) and 8GB VRAM which should be plenty for editing/ other graphics intensive work.
He was very clear about preferring Nvidia. Why the heck people don't understand it? Bang for the buck won't matter in a situation like this. Who knows, maybe he has a Gsync monitor, or his past experiences with AMD are so terrible that he want's to stay far away from them.
@Ron12777 As it shows in @boggy77 post, a GTX 1050 will get you there without a problem. A potato runs Overwatch.
Edited by HumdrumPenguin
39 minutes ago, Ron12777 said:
What is the minimum requirements for reliable 60fps ultra settings in overwatch. No rtx cards. No AMD. Its ok if it goes down to 40fps in intense scenes
I may have missed your actual specs and the resolution you're using...
