hi guys im new here and I need help for my hard drive
so currently I have old computer
with:
amd athlon x2 240 (OC 3.24GHZ)
gt1030
8gb ram
and I want to upgrade to Intel i5-3570 but the problem is my hard drive I have tons of games and video project and I don't wanna o reinstall the whole OS and I'm using windows 7 and soon will upgrade to windows 10 what should I do should I install windows 10 as well for my CPU +mobo  I read other forum they had no problem is this true for windows 10 ?
regards
proxym1ty
*(I know most of you guys said do clean install but NOPE I'm not gonna spend my whole night downloading my games and redo the work)
https://linustechtips.com/topic/1161944-i-need-help-for-my-hard-disk/
Why are you "upgrading" to a 3570?
Yes you should reinstall. Windows does NOT handle driver cycling perfectly and can cause a ton of issues.
Back up the hard drive, or the important files and then use a windows boot device and install windows 10. Do you have an SSD?
hey thanks for replying
my budget enough for 3570 OK its old but I can't stick with 240 no more
no I don't have any ssd and that's my only hard drive
Look into an Anthlon 200/300GE. MUCH better upragrade paths with those and a B450 board
You can get a 1600 AF, cheap b450 board and 8GB of ram for under that price.
hey sorry late reply
tbh all of ur CPU suggestion are out of my budget for example
50$ in Indonesia  its around 750k so I only have budget below 75$ ik I'm such poor guy but wut else can I do for it
2 hours ago, proxym1ty said:
OK so let's go back on topic soi have this called cloning I found software called aomei backup
eh its says it can backup/restore system image to new computer correct? should I use this method ?
In short, no. In long, noooooo. Do a fresh install, a clone is pointless as it also keeps the old booked registry files and useless drivers
