Good afternoon. I have purchased Sonnet Breakaway Box 650 and have run into several issues. The Box would not properly connect to my laptop. After connecting Thunderbolt 3 cable box turns on and connects, but shortly after loses connection and constantly fluctuates between on and off about every 3-5 seconds. All the drivers are updated to the latest version (BIOS, Thunderbolt, and GPU). I have tried purchasing a different Thunderbolt 3 cable, thinking the issues might be it. It seemed to work for a bit, but then the issue persisted. I have also tried swapping for a different GPU and even connecting the box to my laptop without a GPU in, the same issue.
Razer Blade Stealth I7 7500U (2017)
GPU: R9 Fury X (Sonnet says GPU is supported by the Box)
Thunderbolt NVM Firmware version: 9.00
BIOS version: Razer 1.50, 2/26/2018 (Newest, according to Razer)
Windows 10 Version: 10.0.18362 Build 18362
https://linustechtips.com/topic/1161498-egpu-connection-issue/
Did you buy this breakaway box new?
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/1161498-egpu-connection-issue/#findComment-13344089
