Unplug it and use microfiber cloth, small amount of water can't harm, but pro advice is:
Quote
Isopropyl alcohol is a fairly mild solvent, even at 99% purity it's not powerful enough to attack the plastic layers over the screen. Just use some microfiber cloth, place a few drops on the microfiber cloth and clean the screen in straight vertical moves, top to bottom and left to right.
Unless you mean, clean the inside?
https://linustechtips.com/topic/1161012-cleaning/#findComment-13339697
