So I have the NZXT Manta case and I wanted a new GPU (this one in fact) but I'm worried about the clearance. On the GPU page is says its size, lenght, height and width but on all of the sites it just says "GPU clearance is 363mm." 363 what? Lenght? Height? All toghether combined?
If someone could help me and explain how this clearance is measured that would be great and if the GPU fits or not.
Thanks
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1160101-is-gpu-too-big-for-case/
Thanks
Length of the videocard.
Also known as the largest measurement on the videocard manufacturers website:
So seeing as the case fits up to 363mm and the videocard is 264mm, you're all fine.
I've owned a NZXT manta and its got a huge amount of space for a GPU. It fit a Gigabyte GTX 980Ti win the 3 fan windforce cooler if thats any help.
I'm an IT System Admin with 15+ years worth of XP, plus I've been tinkering computers since I was old enough to hold a screwdriver, so I usually know what I'm talking about.
Length is no problem, height I'm not too sure but from the fact that it holds a 120mm rear exhaust, means it should be fine. What I do have problem with is your card choice, TUF X3 is just unnecessarily large for a 1660S and TUF cards in general didnt perform well for something that big.
Desktop benching:
1 hour ago, Arwanell said:
It's not 363mm, impossible
My  Sapphire Fury was huge, one of the biggest cards ever seen, and it was 310mm
It's like @minibois said
I don't have a refference point as this is my first PC that I built and thus first case, but both Gamesnexus and NZXT faq section says it 363mm max GPU length.
If there are better suggestions go for it. I'm just worried about temps as I have a front mounted radiator for my 2700X and I'm worried that cool air won't get to the GPU and others have suggested the best thing I could look for is the coolest running cards (with still decent performance). Also would kinda want a GPU that doensn't die after 5 years (been seeing lots of 900 series cards die lately on pcmr subreddit). I just saw that one is the biggest cards, connected the two dots and here I am :D
Are the TUF cards some big red flag that I don't know about? I've only had 2 GPU's and both were asus, so I'm thinking the 3rd time will be the same (but those were ROG series, or at least looks similar to that style).
fthV4Sh7w7AFQBv_nUPt2mcoSIOG4xlBjfISE-Qg
This is a 267mm long card and there definitely isnt anywhere near 100mm extra space for the graphics card unless there's no fan or radiator (I do believe the radiator is mounted up top in this picture) in the front, letting the card protrude into the curved front panel.
EVGA XC Ultra or MSI Gaming X are the best, no need for the really overbuilt cards such as the Strix. Plus points for EVGA's customer service
Are they reference PCBs? Because older Nvidia cards are known for really, "barely good enough to run" reference PCBs.
and besides, the number of dead cards you see means nothing to the total amount of them Nvidia sold.
Imagine the budget of building the Dual but physically bigger, that's what most TUF cards are. At best they spend an extra fan worth of cost on the cooler, that's about it.
Desktop benching:
Yes, the 363mm length is likely with the fans and radiator taken off, thus max possible length.
And it's a good idea to maybe look for cheaper alternatives than the most expensive variant of a card. I'll just look for things that I need as a minimum such as 2 Displayport ports and something that fits my case.
Cheers. I guess there's still more looking around to do.
