Hey this is my first time posting on this site. Not sure if I’m posting in the wrong area for this, sorry if I am. I’m just wondering if there is any parts on my pc I can change out for better performance. I’ve been told changing my GTX 1050ti for GTX 970 would be better and I realised that the 970 has better performance. Now I’m just curious if there is anything else I should change out. Here are my specs.
motherboard: MSI Z390-A Pro (XMP Enabled)
cpu: Intel i3-9100F 3.6Ghz Turbo 4.2Ghz
gpu: ASUS Cerberus GeForce GTX 1050ti 4GB
ram: 16gb Corsair Vegeance LPX C15 3000mhz
hdd/os: 1TB western digital blue
ssd/games: Kingston 240gb
psu: Casecom 800w 80plus
fans: 4x Deepcool rgb & 2x gamemaxx mirage
case: Deepcool Matrexx 55
os: Windows 10 Professional
https://linustechtips.com/topic/1159929-need-help/
Huh, a z390 board with an i3... Well I've now seen everything. It's not a bad CPU, but not what I'd expect to see on the "higher end" boards.
Personally, I'd upgrade to the i5 9600 or higher and get rid of the HDD for a large capacity SSD, use said larger capacity SSD for games and use the existing 240GB SSD for the OS. This would help reduce the overall noise of the machine too.
https://linustechtips.com/topic/1159929-need-help/#findComment-13331226
