All of my game run a 15% GPU usage. and not more than that.
i try so many thing to try to fix my Issue. Few Exemple down here.
1-Disable HPET
2- Set powersaving to Perfomance in every place possible like Nvidia Control panel
3- Set GPU 1080ti ass my main GPU even if he chose it automatically
4- Trying to overclocking GPU or other part like (CPU-RAM)
5- Update my driver to the most recent version
And much more !
I need tips or help. i saw someone getting the same issue and he fix it by Full Reboot is PC. but i dont want chose this option because i have so much stuff to keep and i wan't intall everything
PC-
Aorus 1080TI
Nvidia 1060 (i only use this GPU Dedicate to my stream to keep the performance max out of my 1080TI when i stream on twitch)
Z270 Asrock Fatality K6
4x8 DDR4 3200MAH (32G)
Intel I7 7700k
Window 10 Version 1909
NVME 500G Storage
HDD 1TO Backup save Storage
any idea or tips ?
(More information)- Seen like only my CPu hit 40-60% on everygame. and sometime hit 70%!!
https://linustechtips.com/topic/1158008-gpu-low-usage-help/
Does taking out the 1060 change anything? And where do you get the 15% usage figure from?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1158008-gpu-low-usage-help/#findComment-13315674
I never try to remove my 1060 Yet but can be a idea
i get the 15% on my Aorus Graphic card control . he show me 15% in GPU usage when i play on a game .
show me the same thing on Task manager and Msi afterburner
https://linustechtips.com/topic/1158008-gpu-low-usage-help/#findComment-13315677
Are you sure that the 15% reading is related to the 1080Ti? And do you feel like the in-game performance is also bad or is it just the usage reading that's low but performance is normal?
https://linustechtips.com/topic/1158008-gpu-low-usage-help/#findComment-13315690
Yeah i got hight Stutering and massif FPS drop . and no i can tell you the 15% are related to the 1080Ti because i can watch both at the same time and the 1060 run at 0% because i dont use it at all . only for streaming
There a tiny exemple of my current Usage
https://linustechtips.com/topic/1158008-gpu-low-usage-help/#findComment-13315693
Right, well again, try removing the 1060 and leaving just the 1080Ti in, and you could also try using DDU to remove the current graphics driver and install a fresh one off Nvidia's website just in case.
https://linustechtips.com/topic/1158008-gpu-low-usage-help/#findComment-13315701
