Common post, I know, stop buli to me >;(
I tried 3 different coolers, 2 different pastes. (Stock, Scythe Ninja 5, H100i V2, Included paste with the Scythe Ninja 5, and Ceramique 2, which from my previous tests is better than MX-4)
As set in ryzen master: CCD0 4.2ghz CCD1 4.0ghz 1.1v core (vcore set to 1.1v in the bios)
Temperatures averages observed using HWinfo, test used was Aida 64 cpu+fpu, Cinebench R20, and 2 simultaneous libx265 encodes, 1080p, main 10, slow, animation, CRF18
Stock: 94c - 86c - 95c
Scythe Ninja 5: 83c - 73c - 84c (Spikes up to 90c+ still happens a fair amount)
H100i V2 (slow pump rpm): 99c - 91c - 99c
Scythe ninja 5 stock paste was approximately 0.5c better than Ceramique 2.
I see others get lower temps at higher volts so I'm pretty confused.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/1157166-3900x-high-temps/
Is 1.1V what it’s running at during the tests?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308552
Yes, it never differs. It's always at 1.1v
Forgot to mention, the Scythe Ninja 5 literally never gets warm to the touch and whenever the test ends or is turned off, the temps drop from the average to 40c (idle) in just a second or two.
Specs v-v
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308561
Thought i’d Make sure. What about just PBO? Iirc flat out overclocking on ryzen 3000. Had some weird issues but I could be mistaken
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308573
I also see temps in 90*C territory when I run mine with NH-U12A (but stock).
1.1V should definitely result in a lot lower temps though. Whats the power usage reported in HWinfo? I get around 140W when runing Aida64 stress test and my CCD1 tends to spike to 95*C for a few ms from time to time.
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308574
Using manual only, stock settings had higher temps, voltages, and lower clocks.
TDC: 90a
EDC: 114a
Power: 141.5w
average temperature: 87.4c
(Doing other stuff at the same time probably has an effect for this run)
Specs v-v
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308586
TDC: 90a
EDC: 114a
Power: 141.5w
well, lower voltage but more current and the same power.... seems like either we both have a bad mount or there is some bad solder between IHS and the die.
From buildzoid video i've seen yesterday he cooled the 3950X until it reached 90*C but it was at 240W on AIO (did't mentioned which one).
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308595
I've remounted this cooler 4 times, testing mounting pressure to see which was best, and there wasnt really a difference.
Specs v-v
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308604
What case and fan setup are you using?
When I'm running Cinebench R20 and Prime95 I never see it going over 73C with fans under 900 RPM and pump at 100% RPM. The highest I've seen my temperatures was around 82C when I'm playing a MMO with 18 instances running when it loads up a new zone data, and if I had the computer on for several hours. My temperatures look about the same as what I was getting with a 2700x. I never tried a X570 motherboard, but I wondered if it because I'm on a B450 or if I just got lucky with a really cool chip.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
https://linustechtips.com/topic/1157166-3900x-high-temps/#findComment-13308731
