PC problems
Go to solution Solved by Shay Green,
Power supply wasn't the issue, swapped it into another pc and it was fine, also tried the paperclip test, thank you @minibois. RAM also wasn't the issue, now I tried swapping the motherboard and straight away it bursts into life. Someone must have been fried in the motherboard when the power was cut abruptly. Apparently very rare but can happen. Ordered a new one for tomorrow.
3 minutes ago, Shay Green said:
My dad was making a shelf, moved my pc and the power cable fell out and now it wont turn back on, please help. Is my power supply fried?
1. Was the PC turned on when this happens?
2. If you take out the power cable from the PSU, does the socket look alright?
3. In what way does it not turn on?
4. Does anything turn on still, like any fans, LEDs, your peripherals, etc.?
https://linustechtips.com/topic/1156529-pc-problems/#findComment-13303267
1. It was running
2. The pins look fine
3. Nothing at all happens
4. Nothing turns on at all
In that case I would fully unplug the PSU from your PC and try the paperclip method of turning on your PSU to see if that does anything at all.
https://linustechtips.com/topic/1156529-pc-problems/#findComment-13303291
Is the psu turned off?
https://linustechtips.com/topic/1156529-pc-problems/#findComment-13303463
Just now, Shay Green said:
No it is verry much on, but the pc shows no signs at all of life
Go inside and see if all the cables are correctly seated
https://linustechtips.com/topic/1156529-pc-problems/#findComment-13303705
https://linustechtips.com/topic/1156529-pc-problems/#findComment-13306068
  • 2 weeks later...
