Laptop sound to PC
Exonick
Hello, title says it all. I'm looking for a way to transfer audio from laptop to pc with as little as possible latency.
Reason: I like to use my laptop with synthesia to play piano.
Laptop headphone jack to desktop mic / line in jack?
Ryzen 5 3600 | Nvidia Quadro P400 | Gigabyte B550I Aorus Pro AX | Klevv Bolt XR 2x8GB DDR4-3600 CL18
Acer Chromebook C720 @ GalliumOS
Pretty much the above. Interference might be a issue if laptops audio chip is weak. But you can counter that by using USB DAC.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
You can try "Chromecast Audio". Its nor free, but it will be work. If i correctly understand you.
Alright I'll try that, I assumed that It wouldn't be that easy.
Thanks
