M.2 ssd problem
Go to solution Solved by Jurrunio,
Try use different SATA ports for the old SSD. I havent checked exactly whether this board disables SATA ports when you use SATA (or any) SSD in the M.2 slot, but some do.
I am pretty new to building computers and i wanted some help with a problem i encountered while upgrading my computer's storage. I got a new crucial sata m.2 ssd mx500 but when i installed it my pc wouldn't boot windows from my old sata ssd and my old ssd didnt even show up in the BIOS, so i kept switching the SATA cables connected to my old sata ssd but nothing worked, Then i tried putting my m.2 ssd in another slot in my motherboard which made windows boot from my old ssd but the m.2 ssd didnt work and didnt show up in the BIOS when i opened windows. I need any suggestions as to what my problem is and how i should solve it.
Pc specs:
Ryzen 7 3700x
B450-f motherboard
Gtx 1060
16gb ram 3000mhz
480gb kingston SATA ssd (old ssd)
500gb crucial SATA m.2 ssd MX500 (new ssd)
600w power supply
https://linustechtips.com/topic/1155609-m2-ssd-problem/
Pc specs:
Ryzen 7 3700x
B450-f motherboard
Gtx 1060
16gb ram 3000mhz
600w power supply
Often when m.2’s are inserted, certain sata lanes are disabled.
check your manual or someone here will maybe tell you which ones.
https://linustechtips.com/topic/1155609-m2-ssd-problem/#findComment-13296840
Desktop benching:
https://linustechtips.com/topic/1155609-m2-ssd-problem/#findComment-13296848
